Circles exported as KMZs show up as ovals on google earth
2905
06-02-2021 05:05 PM
SohrabMikanik
I am having an issue that has been ongoing for months now, but every time I make a buffer from a point layer that is a circle when I export as a KMZ it turns into an oval.  I have played with the settings and can't seem to get any different results.  See picture below.
Tags (3)
DanPatterson
MVP Esteemed Contributor
geodesic buffers will be shape preserving
How Buffer (Analysis) works—ArcGIS Pro | Documentation
... sort of retired...
forestknutsen1
I think you might be having a projection issue. Google uses web mercator auxiliary sphere. What projection is your Arc project in? Try getting the project in web mercator before creating the buffers.
DrVSSKiran
Make sure the feature class geographic coordinate system should be GCS WGS 84. I have created a feature class and digitized one circle. Refer below screenshot.
Now use layer to KML gp tool to export the Kmz fir.
Here is the exported results
SohrabMikanik
Thank you for your response, my projects are always in WGS 1984 web mercator by default since most of what I do ends up online.  I still get an oval, I had to export use a geodesic buffer to get it right.
DanPatterson
RandyMcGregor_BMcD
4/28/2025 and this little piece of info. was a life-saver. Thank you!
