Check / uncheck "Only show features visible in the map extent" for legend using ArcPy
1548
03-30-2021 05:30 PM
DavidField
Does anyone know if there is code that can be used to check / uncheck the legend option "Only show features visible in the map extent"?
I seem to spend hours sorting through my layouts turning this on.
JayantaPoddar
Does this work for you?
showVisibleFeatures : A Boolean that controls whether the legend item displays all values or only those values that appear in the visible extent.
Please check the sample code in LegendItem
Think Location
JayantaPoddar
Think Location
DavidField
Perfect - thank you!
JF7
I try the property showVisibleFeatures and dont work. I try other property's and work fine, but  showVisibleFeatures  fail.   Anyone with same problem?  A bug ???
