change fieldname join_count to other fieldname in spatial join
1080
12-24-2021 12:03 AM
ArjenvanHartingsveldt
I often perform a Spatial join to count the number of features within an area. This number ends up in the 'join_count' field. Then I have to change this fieldname join_count to an other name. Is there a way to do this change within the Spatial Join-tool?
DanPatterson
MVP Esteemed Contributor
There are no builtin options since the names are pre-defined
Spatial Join (Analysis)—ArcGIS Pro | Documentation
If you are coding this in python you could try adding this to your workflow
Alter Field (Data Management)—ArcGIS Pro | Documentation
... sort of retired...
Thanks. I put these 2 tools together in this model, now it works how I wished: SpatialJoinFieldName.JPG
