CCTV Manager Solution - modelbuilder iteration fails when using inline variable substitution
858
03-03-2021 11:48 AM
GISUser74305830
New Contributor III
I am using the CCTV Manager Solution. I am trying to create a model to iterate over a series of folders and run the Import Access Tables script on the MDB file within. I am using inline variable substitution to construct the Access database file path. The script will not accept what I try to pass into it.
The Access database parameter is set as a File type. It works if I hardcode the Access database. But when I try to construct the Access database path using inline variable substitution, it errors out and won't accept that.
  • The MDB file is located here:
    • C:\CCTV_Inspections\2020_05_11\2020_05_11_PACP _ LACP _ MACP 6.0.mdb
  • The iterator produces the following output:
    • Folder - i.e. C:\CCTV_Inspections\2020_05_11
    • Folder Name - i.e. 2020_05_11
  • I've constructed the Access database name using inline variable substitution:
    • %Folder%\%Folder Name%_PACP _ LACP _ MACP 6.0.mdb
    • When translated, it matches exactly the MDB file path
Here is my model:
DanPatterson
MVP Esteemed Contributor
It doesn't produce a valid name
folder = "C:\CCTV_Inspections\2020_05_11"
folder_name = "2020_05_11"
txt = "_PACP _ LACP _ MACP 6.0.mdb"
folder + folder_name + txt
 'C:\\CCTV_Inspections\x820_05_112020_05_11_PACP _ LACP _ MACP 6.0.mdb'
Raw encoding does
folder = r"C:\CCTV_Inspections\2020_05_11"
folder_name = r"2020_05_11"
txt = r"_PACP _ LACP _ MACP 6.0.mdb"
'C:\\CCTV_Inspections\\2020_05_112020_05_11_PACP _ LACP _ MACP 6.0.mdb'
And never use folders that begin with numbers, a, r, t, and a bunch of other characters too many to list
... sort of retired...
GISUser74305830
New Contributor III
what am i doing wrong?
DanPatterson
Your paths aren't able to make a valid filepath when concatenated together, hence my example of "raw encoding" by adding the little 'r' to the front of each element.
GISUser74305830
New Contributor III
Can you raw encode in Modelbuilder?
DanPatterson
I use python not modelbuilder, but I suspect this is why this tool exists for modelbuilder
Parse Path (ModelBuilder)—ArcGIS Pro | Documentation
but I haven't used it
