Catalogue pane can't see items in Geodatabase
2412
6
05-21-2021 09:06 AM
Labels (2)
DavidJohnstone
In the catalogue pane in ArcPro I cannot see inside a feature dataset. I know there are feature classes there because I can drag and drop them onto a map. Has anyone else had this issue. I'm using version 2.8.0-Thanks
Todd_Metzler
Newly created content?  Do you see the same result when viewing in Catalog View?The ArcGISIndexingServer and ArcGIS Pro User profile defined Options > Indexing settings can cause content to not show up depending on the settings.
DavidJohnstone
Hello Todd
Yes the result is the same in catalogue view. I haven't changed anything in the user profile, but I have than updated to the latest version.
If I make a new feature class, it appears automatically on the map, but can't be seen in the catalogue view
If I copy a feature dataset and paste special into a new gdb the feature classes can be seen, however I cannot do this for feature classes not in a feature dataset because I can't see them. If I copy and paste the whole database it has the same problem. If I try and export feature class to geodatabase it doesn't pick up the feature classes.
If I look at an old backup on an external drive it has the same problem although when I made the backup it didn't have this problem, its only been in the last week. I'm thinking maybe a file is missing or has been deleted in error
So I have a partial solution with copy and paste special and I have the other datasets so just a bit of extra work required
JayantaPoddar
What happens when you refresh the parent geodatabase or restart ArcGIS Pro? Does the issue persist in  a new ArcGIS Pro Project?
Think Location
DavidJohnstone
Hello Jayanta
Refreshing/restarting has no effect. Also previous backups of the project have the same problem even though they didn't have the issue when the backups were made.  If I add a .gdb from a different project into the catalogue pane I can see the different datasets within it, so the problem is only with this particular gdb.  If I create a completely new project it does not have this problem
temprobertcottreau131313
try using in Catalog View not Catalog Pane
Sean_Wray
I was experiencing the same problem. I had 1 feature class inside my feature dataset that I could not see. I added it to the map. Then I filled in the label (see image). Then I refreshed my GDB in the catalog pane and it now I can see it. Maybe it has to do with the feature class not having a label when it was created???
