Catalog Layers: Display more than ten items in view?
1004
08-19-2024 01:53 PM
AlfredBaldenweck
MVP Regular Contributor
Hi all,
I'm experimenting with Catalog Layers and I'm wondering if it's possible to show more than 10 layers at a time with them? Some of my catalog layers have like 18 different feeder files that are all within my current extent, but only 10 max show up for me.
Is there a way to show more than 10?
In this picture, I show the entire extent of the catalog dataset, containing 18 records. Only 10 draw at a time under "Layers in View"
DanPatterson
From
Work with catalog layers—ArcGIS Pro | Documentation
The Layers In View composite layer dynamically updates to display dataset items in the current view. By default, Layers In View draws up to 10 layers at a time. This default setting can be changed by adjusting the layer limit. Additionally, the layer can be filtered to show dataset items in a defined scale range, time, range, or other property. Because the layer is dynamic, its list of catalog dataset items in the Contents pane changes as you pan, zoom, or change the view's extent. A layer limit prevents the catalog layer from displaying all items in the dataset. This is useful for filtering out items that may consume additional resources.
... sort of retired...
DanPatterson
From
AlfredBaldenweck
Thanks, Dan.
I was expecting it to be in the layer properties window (of which there are three for each catalog layer). It is instead here in the Ribbon:
You can also edit it directly in the LYRX, or using CIM (although I can't find it in the CIM documentation but I'm not looking too hard).
dft = lay.getDefinition('V3')
dir(dft)
['__class__', '__delattr__', '__dict__', '__dir__',
'__doc__', '__eq__', '__format__', '__ge__',
'__getattribute__', '__gt__', '__hash__', '__init__',
'__init_subclass__', '__le__', '__lt__', '__module__',
'__ne__', '__new__', '__reduce__', '__reduce_ex__',
'__repr__', '__setattr__', '__sizeof__', '__str__',
'__subclasshook__', '__weakref__', 'allowDrapingOnIntegratedMesh',
'attribution', 'autoGenerateFeatureTemplates', 'blendingMode',
'catalogDynamicGroupLayer', 'charts', 'customProperties', 'description',
'displayCacheType', 'displayFilterChoices', 'displayFilterName',
'displayFilters', 'displayFiltersType', 'enableDisplayFilters', 'expanded',
'extrusion', 'featureBlendingMode', 'featureCacheType',
'featureElevationExpression', 'featureElevationExpressionInfo',
'featureSortInfos', 'featureTable', 'featureTemplates', 'footprintLayer',
'htmlPopupEnabled', 'htmlPopupFormat', 'isFlattened', 'layer3DProperties',
'layerElevation', 'layerMasks', 'layerTemplate', 'layerType',
'maxDisplayCacheAge', 'maxScale', 'maximumVisibleSublayers', 'metadataURI',
'minScale', 'name', 'pageDefinition', 'polygonSelectionFillColor',
'popupInfo', 'rasterizeOnExport', 'refreshRate', 'refreshRateUnit',
'searchable', 'selectable', 'selectionColor', 'selectionSymbol',
'serviceLayerID', 'showLegends', 'showMapTips', 'showPopups',
'sourceModifiedTime', 'sourcePortalUrl', 'sourceURI', 'transparency', 'uRI',
'useSelectionSymbol', 'useSourceMetadata', 'useVisibilityTimeExtent',
'visibility', 'visibilityTimeExtent', 'webMapLayerID']
AlfredBaldenweck
Actually it looks like setting the definition in CIM causes Pro to crash on 3.1 lol. Beware, everyone.
