I'm currently editing a map using ArcGIS Pro 2.2, but because the base map I'm using is predominantly green in this one area I'm finding it very difficult to see the vertices (because they're also green).
Is there a way to change the color if the vertices in ArcGIS Pro?
Mark,
You can use symbol setting to place a marker on the vertices.
Add a marker layer
Then set up the marker symbol, choose the shape of your choice from a font.
Then set the Marker Placement to be 'On vertices'.
Whether editing a feature or not, you will be able to see where the vertices are.
Mark
There doesn't seem to be a vertex properties option at all
Dan:
Thanks...even though you could not find a solution, I'm finding comfort in the fact that my own research methods are probably not that bad :-). I will use a work-around I guess (i.e. temporarily use a different base map while editing).
perfect solution
Mark,
Add a marker layer
Mark
Mark:
Thanks a million. I had an inkling that something like this should be achievable in ArcGIS Pro...never thought of looking there though. Awesome solution...this will work well I'm sure.
