Can't sign in to my portal in Arcgis Pro
4327
07-14-2019 06:14 PM
MatiurAri
I've made my arcgis account using google credential and I have an organization with ArcGIS Pro license, my problem is I can't sign in with Pro because it does not have google sign in option. How can I sign in to Pro using google credential?
DanielUrbach
Matiur,
Can you confirm that you have the box checked under your organization's Settings > Security > Social Logins > Configure.
If you are not able to do this, try to change your active Portal in ArcGIS Pro to https://www.arcgis.com, you should see the option to sign in with your Google account then and if that account is a member of the organization in question, you should have access to it at this point.
-Danny
JakeSimms1
Matiur,
What version of ArcGIS Pro are you using?
Jake
MatiurAri
I'm using 2.4.0 ArcGIS Pro
DanielUrbach
Matiur,
-Danny
MatiurAri
Daniel,
Thank you very much, I can sign in to ArcGIS Pro now. Google sign in option only available in http://www.arcgis.com portal. I still can't sign in to myorg.maps.arcgis.com portal in ArcGIS Pro because it doesn't have google sign in option.
