Can't login to ArcGIS Pro
7125
7
06-11-2017 01:26 PM
La_OdeAbdul_Hafid1
I can't login to ArcGIS Pro although I have a valid trial AGOL account. And the Licensing window keeps pop up.
Any helps?
La_OdeAbdul_Hafid1
I think the problem lies in my operating system. After I reinstalL my PC, the problem was solved. Thanks for all the responses.
DanPatterson_Retired
there is a separate set of instructions to activate PRO see
https://community.esri.com/thread/170392
but you have to go back to trial.arcgis.com  to fix it and complete the process
La_OdeAbdul_Hafid1
I have followed all these steps
and there is no problem at all but still I can't login to PRO.
If you have administrator privileges for your ArcGIS online account and did steps 1 through 5, except the last bullet... there is an issue or something is different with your AGOL account
La_OdeAbdul_Hafid1
So the solution? I think if I can login in AGOL successfully using my trial account, I can also login in PRO..
JayantaPoddar
You need to login to ArcGIS Online trial account through a browser. Then, Configure ArcGIS Pro License to one member . Once the license is assigned to the member, you can connect to the licensing Portal using ArcGIS Pro
The URL of the licensing portal will be formatted as https://<yourorg>.maps.arcgis.com
Think Location
TimOrmsby
When you start ArcGIS Pro, did you see a sign-in screen before the Licensing dialog box appeared? The sign-in screen looks like the image below. (Also, if you click OK on the Licensing dialog box, it should bring you to this sign-in screen.)
You need to sign in with a username and password from your trial organization. The user must be a Level 2 user with an ArcGIS Pro license from the steps you followed in Activate ArcGIS Pro licenses for your organization.  When you try to sign in on the sign-in screen what happens to you?
La_OdeAbdul_Hafid1
