can not get the edit vertices tool to work.
2199
07-17-2024 11:02 AM
Laura_m_Conner
All,
I can not get the edit vertices tool to work. It was working fine yesterday and now it not.  This is hindering ability to preform edits. I have read the other thread on the mater but are still unable to solve the problem. I need a solution or work around because edits are a major part of my job.
Here are the steps I have took to troubleshot the problem
make sure only 1 line is selected.
exiting and reentering the pro
updating from 3.3 to 3.3.1
switching to a different version of the database
deleting and recreating the version I was in
splitting the line so it would not have as may vertices ( it a curved line and we don't use Bezier cruves)
checking the rotation of the map and making sure it is set to 0
The issue priest. I need the abilty to edit lines  do my job
details
arc pro 3.3.1 and 3.3
Thank You
Laura_m_Conner
the solution that worked for me is to remove the layer and reload it.
Note I also tried restarting the computer to apply some updates that did not work.
Laura_m_Conner
It is working fine for my coworkers.
Laura_m_Conner
Also to note I can edit vertices on other feature classes but i not working for 1 of them.
Laura_m_Conner
RichardHeal
So I had a similar problem with Edit Vertices.  Could not get it to work in 3.3.1.  Solution was to copy the Feature Class to a new file geodatabase.
