Can Centroid($feature) be used to populate lat/lon with attribute rule?
1910
8
01-16-2020 12:06 PM
ThomasColson
MVP Frequent Contributor
I see Geometry Functions | ArcGIS for Developers  exists but how would one call that to populate separate lat and lon fields with an attribute rule?
KellyKoenig
You can access the lat/long individually by adding ".X" or ".Y" to the end of Geometry($feature), so your attribute rule would be:
return Geometry($feature).Y
for Latitude, and
return Geometry($feature).X
for Longitude.
Arcade expression for Latitude
KellyKoenig
for Latitude, and
for Longitude.
ThomasColson
Attribute rules are so cool.
KellyKoenig
Totally agree. They're like magic!
DezsoLovicsek
Is there a way to return the geometry in a different coordinate system? For example, my layer is in NAD83 but I would like for the WGS 84 coordinates to auto-populate in the attribute table.
AnneSantaMaria
Has anyone been able to figure out if it is possible to populate an x,y or for that matter any geometry field (extents for example) in a coordinate system other than the one the feature class is project in?
RebeccaBasquez1
Hello Kelly,
I'm trying to use this expression in ArcPro 2.9.1 and I get an error. See attached. What am I doing wrong? Any help would be greatly appreciated.
DrewDowling
will only work on point features. Try this instead:
return Centroid(Geometry($feature)).Y
_Kara_
Is it possible to convert the result? I am working in WGS 1984 UTM Zone 6N and would like the final result in lat/long decimal degrees rather than Northing and Easting.
