Can be set topology rules prior to creating a dataset in arcgis pro?
778
11-20-2022 10:30 PM
Som_NThakur
I am going to digiting the liner feature and wanted to set some topological rules like must not overlap, intersect, undershoot and overshoot etc. on the feature data set before starting the digitization.  Is it possible to set such rules before starting digitization?
DanPatterson
MVP Esteemed Contributor
Are you following the steps here?
Is the featureclass already created and you just need to digitize
Geodatabase topology—ArcGIS Pro | Documentation
The first step includes creating a geodatabase topology for the dataset containing the features participating in the topology. You can right-click the dataset in the Catalog pane, or use the geoprocessing toolset.
... sort of retired...
