Calculate Z Geometry of a point feature with value from a field in Attribute table
3435
6
02-24-2021 10:40 AM
MelissaSalich
I need to populate the Z Geometry Attribute of a point feature class.
I have the Z value as a field in the attribute table.
How can I script this process to avoid having to hand type the elevation valves when I have the data already?
Pro 2.7, file gdb.
Field in Attribute table:
DanPatterson
MVP Esteemed Contributor
DanPatterson
If you have the 3D analyst extension
Feature To 3D By Attribute (3D Analyst)—ArcGIS Pro | Documentation
... sort of retired...
MelissaSalich
thank you! exactly what i was looking for!
by Anonymous User
Not applicable
If you know Python, you can also update(replace) the Z value from an attribute field.
Take a look at the answer from the following for a starter to update(replace) the Z
https://gis.stackexchange.com/questions/329511/updating-z-value-of-geometry-using-updatecursor
MelissaSalich
thank you, I'm bookmarking this for future reference! I used Feature to 3D By Attribute for this situation.
jchester73
New Contributor III
Does Feature to 3D by Attribute create an entirely new feature class or can this be used to replace z values on an existing one?
MelissaSalich
creates new feature class
