Calculate Z Geometry of a point feature with value from a field in Attribute table
354
02-24-2021 10:40 AM
MelissaSalich
New Contributor II
I need to populate the Z Geometry Attribute of a point feature class.
I have the Z value as a field in the attribute table.
How can I script this process to avoid having to hand type the elevation valves when I have the data already?
Pro 2.7, file gdb.
Field in Attribute table:
DanPatterson
MVP Notable Contributor
DanPatterson
MelissaSalich
New Contributor II
thank you! exactly what i was looking for!
SeanJones
If you know Python, you can also update(replace) the Z value from an attribute field.
Take a look at the answer from the following for a starter to update(replace) the Z
https://gis.stackexchange.com/questions/329511/updating-z-value-of-geometry-using-updatecursor
MelissaSalich
New Contributor II
thank you, I'm bookmarking this for future reference! I used Feature to 3D By Attribute for this situation.
