calculate valume of a 3d polygon
450
10-24-2021 10:03 AM
matu89
New Contributor II
hello,
i draw on my surface  a polygon.
i want to calculate the volume inside the polygon.
inside the polygon there are various heights  and there for , the tool "polygon volume" didnt worked for me.
is there a tool or a way to claculate the volume inside the polygon ?
thanks.
DanPatterson
MVP Esteemed Contributor
Didn't work?
What was the error?
Were you using the right type of data?
Were you using data with x, y and z in the same units?
... sort of retired...
matu89
New Contributor II
the point is that the "polygon volume" is nor the right tool to calculate the cause.
i need to find a way to convert this Z polygon to a surface.
is there a way ?
DanPatterson
