Calculate the percent of area for each feature
5514
01-21-2023 05:42 AM
JoshSaad1
I have a polygon feature class representing our county by Land Type, and I'd like to add a field showing the percent of the total area by each type.
I did this before by summarizing to get the total area and manually entering that value into an Arcade expression to calculate the percentage for each feature.
I'm trying to create a model in Model Builder so that I can automate the process in the future, but I'm not sure how to calculate the total area and feed that variable into the Calculate Field tool to get the percentage of each feature.  Does anyone have a suggestion on how to do this?
2 Solutions
DanPatterson
MVP Esteemed Contributor
perhaps Summary Statistics (Analysis)—ArcGIS Pro | Documentation
to get the total area from the shape_area field as input to your model
... sort of retired...
JoshSaad1
Thanks.  That was part of the solution.  I calculated the total area using Summary Statistics, then I had to use a Model Builder utility to get the value of the row so that I could use it as an in-line variable in my Arcade script.  Also, apparently to use an in-line variable in Arcade you have to wrap it in single-quotes, '%variable%'.
DanPatterson
JoshSaad1
I tried that, but I don't have Zone features.  Instead of identifying the percentage of area in each zone for each land type, I want to identify the parentage of area of each land type of the total combined areas.
Thanks.
DanPatterson
JoshSaad1
