Calculate geometry fails for no reason?
2074
07-06-2023 05:12 PM
Mikhail
Hi All, I have an unexpected problem. My shapefile consists of a number of polygons, and I need to know their areas. I select the ID column in the Attribute Table and start Calculate Geometry. It runs but creates no extra columns, so I cannot see where the areas are. In addition, something happens to the ID field, as the IDs change in some random order. I attach screenshots of the Attribute Table before and after running Calculate Geometry. Could someone help?
alex_mapintel
Hi @Mikhail
I would create a new attribute called 'area_<units>' and set the data type to decimal or integer. Then perform the geometry calculate on the new attribute.
In your example, it looks like you are calculating the area of the polygon into the "ID" attribute.
alex_mapintel
Hi @Mikhail
Mikhail
Hi Alex, thank you very much for your advice! I did not realize that the area goes into the selected field.
DanPatterson
MVP Esteemed Contributor
There is no need to select the ID field
Calculate Geometry Attributes (Data Management)—ArcGIS Pro | Documentation
specifies the requirements
... sort of retired...
Mikhail
Thanks, now I have better understanding of how this tool works.
