Calculate Field is applying to all fields, not just selected field
897
6
12-18-2023 07:56 AM
NickAddison
New Contributor III
Trying to add some Arcade expressions to selected fields. Upon applying the expression, it calculates all the fields within the attribute table to have that expression. Why is it applying to all the fields, and not just the selected field?
DanPatterson
MVP Esteemed Contributor
The expression and a screen grab of the table might be useful to tracking down the issue.
... sort of retired...
Amir-Sarrafzadeh-Arasi
Dear Nick,
If you want to do the Arcade expression, you can pass just single Field.
and it will apply the expression on the given field.
Please check the attachment for understading better.
Good luck
Amir Sarrafzadeh Arasi
NickAddison
New Contributor III
This is what was applied to Fire_District_Abrev
I don't believe the expression itself is the issue though. Regardless of what expression (the attached or any different expression) is applied to any field, it applies said expression to all the attribute fields and subsequently rewrites any expression that may have been in the other fields.
Dear Nick,
It works fine in mine table.
Please check the attachment.
Good luck
DanPatterson
It is good that you have Enable Undo active.  So don't save the edits, close the table and see if it is ok.
Did you have any pending unsaved edits prior to using Calculate Field?
CarolineSmith527
I am having this issue as well.
