Boundaries of countries in Sub-Saharan Africa
395
09-08-2024 05:56 PM
GabrielaMundaca
Could anybody provide me information about how to get boundaries for Sub-Saharan Africa?
Thank you
Gabriela M.
CodyPatterson
MVP Regular Contributor
Hey @GabrielaMundaca
I'm not sure if this completely satisfies your request, but this is an ESRI map of all countries in Africa, you may need to create an export of the feature layer with only Sub-Saharan countries, but this should get you started!
https://www.arcgis.com/home/item.html?id=64aff05d66ff443caf9711fd988e21dd
Edit: Here is also a very large data library for African information:
https://www.africageoportal.com/pages/Data%20Library
Cody
GabrielaMundaca
Thank you Cody Patterson.
I need a map of the boundaries of Africa to be able to use it with the
feature in ArcGIS Pro which is: "*Input point features*" because I
need to "*Extract
Values to Points*." I need to extract raster values at point locations.
Any suggestions you may have, I will highly appreciate.
G Mundaca
