Best way of generating least cost path for many start and end points
453
09-16-2020 09:18 AM
OliverHanney
I have trade data with a start and end point for each object as well as a cost surface. I want to find the least cost path between each objects start and end points in the most efficient way possible (as I have data on thousands of objects).
Is there a way of doing this using the functions on pro, using the least cost path tool hasn't worked as it finds the least cost path from an origin point to every potential end point - all I want is from the origin to the corresponding end point.
