Best Practice to use Map paper size for Moblie or smartphone Question ?
462
08-28-2024 04:02 PM
PROBERT68
Honored Contributor
I'd like to get some feedback from GIS users who have done in the past to use Map paper size in use for Mobile type of smartphone (Tablet, cell phone, etc).
This person wants to use the paper size and go with  Avenza Map too.
What is the best or suggest for Map paper size.
I made a map of three different type of and found out the person only want to use it in his moblie !
RTPL_AU
Honored Contributor
Make sure the users know how to use Map Collections in Avenza. This makes distributing high quality maps for large areas easier.
Using Collections also makes the paper size discussion more complex - you can use a map series and footprints best suited to the project area rather than just using a screen dimension.
Also - change the discussion to aspect ratio (4:3, 16:9) rather than pure cm/mm page size.
That way you can create various page sizes that fit a particular screen aspect ratio and thus vary the file size/quality as required.
