Automating date calculation in the Field Calculator
3209
06-15-2021 06:46 AM
DarrenDe_Lange
Good afternoon all!
I am trying to automate date calculations using the field calculator in ArcGIS Pro.
I have defined survey dates, which I would like to use to create a reinspection dates.
The reinspection date is 1 year for high risk zones, 3 years for medium risk zone and 5 years for low risk zones.
Is there a piece of code I could use in the field calculator to automate this calculation?
The best sample I came out with for high risk zones is:
Expression:
arcpy.time.ParseDateTimeString(!SurveyDate!) + datetime.timedelta(days=365)
However, this did not work when I tried to execute the script.
Any help is appreciated.
Thank you
2 Solutions
DavidPike
MVP Notable Contributor
How about !SurveyDate! + datetime.timedelta(days=365)
edit - I can see this same post was answered in Python questions.
DavidPike
I'd post any continuations as new posts to prevent threads becoming a Q and A or bugfixing session.
#Expression line:
reclass(!SurveyDate!, !RiskZone!)
#Code block:
def reclass(SurveyDate, RiskZone):
    if (RiskZone == 'LOW'):
        return SurveyDate + datetime.timedelta(days=486)
    elif (RiskZone == 'MED'):
        return  SurveyDate + datetime.timedelta(days=1095)
    elif (RiskZone = 'HIGH'):
        return SurveyDate + datetime.timedelta(days=1825)
DavidPike
DarrenDe_Lange
Thank you David - I asked in both communities as I didn't know which was more relevant 🙂
DarrenDe_Lange
I am now trying to add in the risk zones and my statement does not seem to be working.
Field Calculator:
Expression line:
reclass(!SurveyDate!)
Code block:
def reclass(SurveyDate):
    if (RiskZone = LOW):
        return "SurveyDate + datetime.timedelta(days=486)"
    elif (RiskZone = MED):
        return return "SurveyDate + datetime.timedelta(days=1095)"
    elif (RiskZone = HIGH):
        return return "SurveyDate + datetime.timedelta(days=1825)"
Attached is the syntax error.
Any assistance is appreciated.
DavidPike
#Expression line:
#Code block:
DarrenDe_Lange
Thank you, will do that in future!
