Attribute table statistics using arcpy (for polyline)
918
03-30-2021 03:22 AM
MohamadAchour
hello, I have a polyline shapefile, and I need to calculate the mean value of one column of its attribute table using arcpy.
Any suggestion?
DanPatterson
import numpy as np
from arcpy.da import SearchCursor
values = np.mean([row[0] for row in SearchCursor(fc, "Shape_Length")])
An equivalent but slower method, if there are no nulls (an extra hoop to jump through is necessary if there are nulls)
... sort of retired...
DanPatterson
As in Summary Statistics (Analysis)—ArcGIS Pro | Documentation
or is it something different you are looking for?
DanPatterson
or perhaps
import numpy as np
from arcpy.da import TableToNumPyArray
fc = r"C:\Git_Dan\npgeom_bak\Project_npg\npgeom.gdb\Ontario_singlepart"
arr = TableToNumPyArray(fc, "Shape_Length", skip_nulls=True)
np.mean(arr["Shape_Length"])
84684.37997765756
MohamadAchour
I will try this one.
Thanks a lot.
DanPatterson
import numpy as np
