Attribute Rule for editor tracking?
66
01-28-2021 02:09 AM
Labels (2)
JessicaEdberg
Hi
I need help to create an attribute rule that can write the value of now() in an attribute field called Attribute_changed when an attribute is changed for an object, and write the value of now() in an attribute field called Geometry_changed if the geometry of an object is changed. I dont think this is possible to specify when I'm useing Editor Tracking in the geodatabas so I want to try use attribute rules. Is it possible to do this with attribute rules and do anybody know how?
I run ArcGIS Pro 2.6.3
Sincerely Jessica
Reply
KoryKramer
Community Moderator
You might also try posting in the Attribute Rules space if you don't get an answer here: https://community.esri.com/t5/attribute-rules-questions/bd-p/attribute-rules-questions
KoryKramer
Community Moderator
