Attribute Assistant for Pro
10241
12
07-14-2016 08:55 AM
KirstynAlex
After one of the Pro sessions at the UC this year I asked if Attribute Assistant is supported. The short response was that the functionality is there but it is not called the same thing. Does anyone know how to set up this functionality in Pro so that, for example, when a new point is created the UniqueID is updated automatically, and it is spatially intersected with Zip Codes to automatically calculate those? I've done some research but am unable to find anything that for Pro that relates to automatically calculating attributes.
Thanks!
LeonS
Reading the "no longer usable in ArcMap" caveat in the help was kind of deflating.  That's going to make the migration to Pro fairly tricky for our organization. I hope that restriction gets removed somehow..
KirstynAlex
Agreed - I appreciate them implementing attribute rules, but due to this caveat it is useless to my organization at this stage since Pro is nowhere near where it needs to be to completely switch over to it.
MichaelVolz
Esteemed Contributor
That is quite a caveat.
