Editing attributes in the Attribute Pane seems more cumbersome in ArcGIS Pro than it is in ArcMap. I have to use my mouse to click into each field to edit instead of simply pressing tab to get to the next field. Pressing the tab key highlights the next field but I still have to click in with the mouse pointer to actually edit. Any advice or tips, hints, or tricks would be appreciated.
I'm glad to report that with the new update to ArcGIS Pro you can now tab through the fields and enter values. Just what the doctor ordered! Thanks Esri!
These might be useful keyboard-shortcuts-for-tables
Thank you! These are very useful shortcuts for tables.
