*** UPDATE*** as of 09/2019 below Issue has been logged as a bug. ***
When using Error Inspector in ArcPro 2.3.3, it inconsistently filters errors to map extent in the error table.
It seems that it will only filter results in the until an attribute table is opened. Once an attribute table is opened the error table will will not refresh and will display only the errors displayed at the time the attribute table was opened.
This has become an issue when trying to filter by rule later so that I can edit specific types of errors in an extent as a batch. #goingbacktoArcMap
Any ideas?
Below is a quick run down of the process and screen shots to give an idea. I have tried this with different maps and data and get the same failure to refresh.
Map Opened.
Hi Rachel,
The image in step 7 shows the map extent filter is off. What steps lead to that being turned off?
Hello Sean,
I turned the map extent filter off in the screen shot to show that even without the filter only 6 errors display when there should be 2000+.
A bit after posting this, I worked with ESRI Tech support on this for a couple weeks and it was reproducible on their end with their data. Unfortunately, it is a bug.
In addition, it doe not appear ArcPro allows me to symbolize topological errors by type. I have decided to return to ArcMap to address this type work.
