ArcPro Explore Tool - Attributes Missing
1482
7
08-28-2020 07:42 AM
ToddHayes
When using the Explore tool ArcGIS Pro to identify attributes for a feature, the pop-up window is only showing one of the fields within that feature class. I have even tried "Configure Pop-ups" to see if that would work and nothing changed. Is this a Bug with ArcGIS Pro 2.6?
Example of ArcGIS Pro Identify Issue
by Anonymous User
Not applicable
I too have observed this after upgrading to ArcPro 2.6 when opening Projects created prior to ArcPro 2.6. When adding new layers in 2.6 Explore tool shows "all available" attributes - but exisitng layers only show the default label field attribute. This is without setting up Popups which I typically avoid on my own data manipulation Projects (not that setting them up on the old layers helps)
CherylWheeler11
Hi, Can I ask if you ever found a solution to this problem please? I am having the same issue. Thanks
ElizabethWheeler
We are also having this issue, June 2021
CherylWheeler11
Hi Elizabeth,
Please see the below link, which is where Robert provided me with a solution.
Hope it helps.
Cheryl
https://community.esri.com/t5/arcgis-pro-questions/arcgis-pro-2-7-popups-only-showing-one-field/m-p/...
ElizabethWheeler
LOL I AM FUMING! This has plagued me and it was so simple.
ElizabethWheeler
Hi Todd,
Did you ever figure this one out?
Robert_LeClair
Esri Notable Contributor
Elizabeth/Todd - to solve this move your mouse to the bottom of the Pop-up.  Your mouse cursor will change to an up/down arrow, click and hold your left mouse key and move the lower (collapsed) portion of the pane to the mid-point of the pop-up.  Now you will see all the attributes as expected.  Click on Cheryl's link above for the other Esri Community post addressing this same issue.
