ArcGIS Pro3.1 to 3.6 can no longer recognize ACAD_PROXY_ENTITY in DWG files
170
a week ago
圈圈
但是在ArcGIS Pro3.0及之前的版本都是可以识别ACAD_PROXY_ENTITY的。有什么办法能让ArcGIS Pro3.6识别出ACAD_PROXY_ENTITY吗?
However, in ArcGIS Pro3.0 and earlier versions, ACAD_PROXY_ENTITY can be recognized. Is there any way for ArcGIS Pro3.6 to recognize ACAD_PROXY_ENTITY?
DEAF_PROBERT_68
Honored Contributor
Question for you ? Do you have FME ?
圈圈
If ArcGIS Pro3.6 could support ACAD_PROXY_ENTITY like 3.0, then I could directly load CAD files into the Pro map to observe the location of ACAD_PROXY_ENTITY.
I have FME, but I don't want to do the conversion through FME because my DWG files are frequently modified.
