ArcGIS Pro unique value renderer, Unable to Add New Value
1544
12-27-2020 10:55 PM
ahmed_hussiney
New Contributor III
I had created ArcGIS Pro project with one Map this map was imported from ArcMap MXD, The map contains multiple layer already symbolized using unique value renderer single or multiple fields, In both cases when I try to add new value to symbol classes using the following steps:
- Right click layer
- Select symbology to open symbology pan
- The Symbology is already using "Unique value" method.
- Then click "add unlisted values" button.
- Then from options click "Add new value"
but rather than add new value and enter value and label it return the following message :
"Requested operation could not be completed"
Note : when I tried in a new Map with layer added and symbolized in ArcGIS pro I can add unlisted value that has no matching data record using "add new value" option.
So what could be the issue in my case, any suggestion ?
DanPatterson
MVP Esteemed Contributor
version of Pro?
BUG-000130218: It is not possible to add unlisted values for Unique.. (esri.com)
and a workaround
... sort of retired...
ahmed_hussiney
New Contributor III
Hi Dan,
Sorry for late response, My ArcGIS Pro version in 2.6.0 , I tried this steps on some layers and it work with no issue, So I don't think it is retired in this version of Pro, But some layers which I had imported from exist MXD is showing this issue and I can't get the root cause of this specially that other layers imported from same MXD is working.
