ArcGIS Pro - "import requests" runs infinitely
530
05-19-2025 02:17 AM
AdamKorejwoTR
Executing the command "import requests" just doesn't finish in a notebook in ArcGIS Pro
I've already tried running it in different projects, updating packages and going back to original environment. None of those helped. Tried it outside of ArcGIS Pro with no issues and on my colleague's computer also with no problems.
What can I do?
DanPatterson
MVP Esteemed Contributor
from the command line in the arcgispro-py3 do a
conda list requests
and see if the installed packages match those listed here (assuming you are using Pro 3.5)
Available third-party Python libraries—ArcGIS Pro | Documentation
... sort of retired...
