ArcGIS Pro Python window can't locate geos_c.dll when importing shapely.geometry
178
05-07-2021 09:35 AM
dlund203
I've been trying to run a Python script in the ArcGIS Pro 2.7.3 window using a cloned environment with shapely 1.6.4 installed. For some reason, every time I try to import shapely.geometry I get the following error:
OSError: Could not find lib geos_c.dll or load any of its variants ['C:\\ArcGISProEnvs\\arcgispro-py3-clone\\Library\\lib\\geos_c.dll'].
I've checked the directory it references and, indeed, there is no geos_c.dll located there. Instead, the dll seems to be located in ..\Library\bin\. When I try importing shapely.geometry from the Python command prompt (with the cloned environment activated) I can do so without issue. Why would the Python window inside Pro specifically be giving me this error? It may be worth mentioning that I recently updated ArcGIS Pro from 2.4, where this issue never showed up.
Here's what I've tried so far:
Reinstalling shapely from the Python command prompt
Downgrading geos to v3.7.1
Pasting in a copy of geos_c.dll from \bin\ into \lib\
Tags (3)
DanPatterson
MVP Honored Contributor
What environment are you connect to when you are within Pro?
... sort of retired...
dlund203
I'm using the same cloned environment. Incidentally, I decided against using shapely altogether because of all the headaches it was causing me, but I'd still like to hear a solution just to satisfy my own curiosity!
