ArcGIS Pro Layout Snapping not working
5428
17
11-09-2017 12:54 PM
GregFiske
It appears that snapping in an ArcPro Layout is still not working.  Can someone say when this will be fixed?
I've read the docs and I think I'm doing it correctly, but I keep getting the same response.  I'm using version 2.0.1.8933
Thanks.
AdrianWelsh
MVP Honored Contributor
Jeanette, maybe it would be worth getting in touch with Esri support if this is stopping you from doing your work?
Robert_LeClair
Esri Notable Contributor
I have not seen ArcGIS Pro 2.4 yet but wonder if it will be addressed with the new update.
Santa_Clara_CountyParks_and_Re
Hi Greg,
I've had the same issue regardless of whether snapping is turned on.  I think this has to do with the margin to the paper edge. Try creating guides at 1/4 inch (or larger), and see if the snapping works okay.
Seth
Nevermind, I can't get it to behave consistently.
CheyneHadley
ArcGIS Pro often forgets that snapping is turned on.  Usually, you can fix this just by restarting the application.
AdrianWelsh
I hadn't tried that one yet... I'll have to remember that!
GregFiske
Hi - the update to ArcPro v2.1.0 fixed this problem.  Thanks
TylerSchwartz2
Occasional Contributor II
I have found that in 2.1.1 that the snapping (in layout view) is automatically enabled every time you reopen a project even though the snapping button shows its off.  You need to cycle it on then off again for snapping to be disabled.  This is a new bug introduced in 2.1.1
