ArcGIS Pro Layout Legend not Displaying Layer Symbology
292
7
02-03-2021 06:55 AM
AlexanderLynch2
New Contributor III
Hello all,
I am having a confusing time trying to understand why my symbology in legend and ToC do not match. ToC has 1 subtype dashed, and rest solid; legend will display symbology as dashed or soild, and of different size. The symbology in legend changes each time an action is done by mouse to the project. It should be noted that I am leveraging attribute property connections.
Thanks!
AlexanderLynch2
New Contributor III
I don't have permissions to do that. However, it does stem from attribute property connections where dash type is set to '1 0 ' but properties mapped to expression in field.
Robert_LeClair
Esri Frequent Contributor
This sounds like BUG-000131848 - Legends using dashed and solid lines are not displayed correctly in ArcGIS Pro as the arrangement between the solid strokes and the shape marker in the layout differs from the arrangement in the map.  It was discovered in ArcGIS Pro 2.5.1 and resolved in ArcGIS Pro 2.7.  What release of ArcGIS Pro are you using?
AlexanderLynch2
New Contributor III
2.7. And to confirm, I downloaded the patch with same results.
Robert_LeClair
Okay - thx for the 2.7 information.  One other thing to try besides a clean uninstall/clean install is to rename the ESRI folder in your C:\Users\<user_profile>\appdata\local and C:\Users\<user_profile>\appdata\roaming to ESRI_OLD and see if that tweaks the legend issue.
AlexanderLynch2
New Contributor III
Current work around is having layer dedicated to legend
TomBole
Hi Alexander,
You may be running into a bug specific to attribute property connections. I'm not aware of any Layout Legend issues with attribute property connections.
Can you contact Esri Support? They are better equipped to handle troubleshooting steps and gather bug data. They can be contacted at https://support.esri.com/en/contact-tech-support.
Tom
AlexanderLynch2
New Contributor III
TomBole
Thanks for the screenshot and bringing this issue to our attention!  I'm able to reproduce this and will enter an internal bug and hopefully we can address this with the next release (2.8).
Tom
