ArcGIS Pro icons randomly disappearing/freezing
2752
12-07-2021 11:51 AM
AndrewSylvia1
Hi all,
I am a student at Northeastern University - I am having some problems trying to use ArcGIS Pro, I've attached a video of what is happening. I had no luck with the Northeastern IT Department and the ArcGIS Technical Support folks referred me here.
KoryKramer
Esri Community Moderator
Hi Andrew,
What version of Pro are you using?
Have you been using it successfully and this issue just started?
There was a recent discussion on graphics issue for users with Alienware: https://community.esri.com/t5/arcgis-pro-questions/arcgis-pro-2-8-ui-glitch/m-p/1110705#M47129  Give that a read.
Otherwise, run through Troubleshooting Performance Issues in ArcGIS Pro , specifically the part about checking system requirements and updating graphics drivers to see if that helps.
Cheers
ABishop
I can't view your video.
Amanda Bishop, GISP
AndrewSylvia1
Sorry, it says it's still being processed. I guess explaining it step by step might help in the meantime. It's basically the first few steps of the homework assignment I've been given.
Step 1. I open ArcGIS and start without a template.
Step 2. go to Catalog > Folders > Add Folder Connection (connecting to the data for the homework)
Step 3. In the geodatabase of that added folder connection, there's a point shape file, I add that to a new map
Step 4. Analysis Tab> Model Builder > Iterators > Iterate Feature Classes
Step 5:  Click on the hexagon for Iterate Feature Classes, then the folder next to workspace or data feature set
Then it looks like this....And when I scroll over the icons, they disappear.
ABishop
Sounds like a bug.  Try repairing ArcGIS Pro.  Also make sure you have all the required clients and drivers necessary to run ArcGIS Pro.
Could be a known bug: https://support.esri.com/en/Search-Results#search?q=arcgis-pro&content-type=Bugs
Amanda Bishop, GISP
KoryKramer
Hi Andrew,
Cheers
AndrewSylvia1
Uninstalling alienware (per that link) did the trick!
