ArcGIS Pro Horizontal Rectangle Shape
287
10-24-2019 05:56 AM
SeanConway
New Contributor II
The option in the above screenshot is available in the ArcMap right click context when drawing a rectangle.  I can't seem to find the same option in ArcGIS Pro, and my searches online have been fruitless.  Can anyone point me to this feature in Pro?
Thanks!
Scott_Harris
Hi Sean,
Until Pro has the horizontal option (hopefully in the near term), you can constrain the rectangle to a specific direction. If your map has no rotation, it can work like this:
In this case, I use "90-1". The "90" specifies 90 degrees and the "-1"  part set the quadrant as northeast. That's because my project direction units are set to Quadrant Bearing:
This can be adapted to any of the direction units.
I hope this helps in the meantime.
Scott
RobertBorchert
Frequent Contributor II
I just recently started using Pro a lot more because Pro works really well for setting up Web Apps and services.
However, I have drawn in thousands  of rectangles using the Horizontal command.
I have found that in a number of ways Pro is superior to ArcMap in many things except editing, labeling, querying, and symbols.
This horizontal thing should be submitted as an idea if it has already not been done.
Scott_Harris
Hi Sean,
Scott
SeanConway
New Contributor II
Very nice workaround. Thank you for that.
