Arcgis Pro - Field Calculator - Change time to 12:00:00AM
2067
10
04-07-2021 10:07 AM
RickeyFight
MVP Regular Contributor
So I have some old data that has time in the date field. I do not want time in the date field.
I know that I can set the time to 12:00:00AM to make the time disappear from the field.
I need a way to update all the records (different days) to have the same time of day but keep the original date.
Any suggestions on how to do this?
jcarlson
MVP Esteemed Contributor
You just need to pull out parts of the date first, then build the new timestamp using the Date function.
var oldDate = $feature["sale_date"]
var y = Text(oldDate, 'Y')
var m = Text(oldDate, 'MM')
var d = Text(oldDate, 'DD')
var newDate = Date(y, m, d, 0)
return newDate
- Josh Carlson
Kendall County GIS
RickeyFight
@jcarlson
Thanks for the quick reply. What language is this in Arcade?
When I run the script as arcade it adds one day and sets the time to 7:00:00AM
jcarlson
Yes, sorry, it's Arcade. You might be dealing with a time zone offset, it sounds like.
- Josh Carlson
Kendall County GIS
RickeyFight
@jcarlson
I got the time to display right by changing to 17 for time. But it keeps adding a month to the calculated value.
this is what my field looks like
and this is what I get after running the script you suggested
var oldDate = $feature.reinspect_date
var newDate = Date(y, m, d, 17)
return newDate
DanPatterson
I will let you get rid of the fluff..  Example using universal format for "now"
from datetime import datetime
n = datetime.now()
new_n = n.replace(hour=12, minute=00)
new_n
datetime.datetime(2021, 4, 7, 12, 0, 11, 262084)
Datetime has a "replace" option
PS
Almost forgot... you can use it to see how things will be in the future... like next year 😉
future = n.replace(minute=00, hour=12, second=00, year=2022, month=4, day=7)
future
datetime.datetime(2022, 4, 7, 12, 0, 0, 262084)
... sort of retired...
RickeyFight
@DanPatterson
Unfortunately  I cannot get your suggestions to work.
JoshuaBixby
Can you elaborate on what isn't working?  Are you getting error messages, unexpected results?
RickeyFight
@JoshuaBixby
I don't know where to start with Dan's suggestion
jcarlson
Instead of "n" being datetime.now(), replace it with the attribute value of the feature.
- Josh Carlson
Kendall County GIS
