ArcGIS Pro feature binning fails with code 999999
436
08-27-2019 08:24 AM
CharlesBailey
New Contributor III
I've been trying to enable feature binning on a point layer, it hangs at 7% and then fails with 99999 random error. Does this even work at all? Thanks, cob
George_Thompson
Esri Frequent Contributor
What is the RDBMS version information, the number of records in the table and the binning settings?
I have gotten it to work on 5.5+MM points.
--- George T.
CharlesBailey
New Contributor III
It’s a sql server 2012 sde database I created with arcmap 10.6.1 because at 2.4 pro can’t create sql 2012 only connect. The tool starts to run normally although at times there is red x on the input parameter until I enter the projection information. There are only about 13K records in this. Do you think it has anything to do with the sql version? Thanks for your response - cob
George_Thompson
Yes, that would be the first place. If the RDBMS is not supported that means that it may not be able to support that function.
I would upgrade the SQL Server version and the Enterprise Geodatabase to 10.7.1 (there may be something that is added as part of the update) and retest.
I would not think that 13k records would cause an issue in the supported environment.
--- George T.
