ArcGIS Pro fails to launch properties and then gets stuck
407
06-28-2023 03:37 PM
ccowin_odfw
Hello,
I wonder if anyone else has seen this behavior, it has happened to me several times. Pro will try and launch properties or some other pop-up menu, it then fails to open but the application is stuck thinking that the pop-up is still visible so you can't interact with the main window. It frustratingly then just beeps at you like your an idiot for not using the other window which doesn't exist. I've had to then end the process every time because it is stuck in a UI/UX dead end.
Has anyone experienced this or figured out a work around?
RyanWalter
Hey - is this on a laptop or desktop? Sometimes there are issues with nVidia drivers and these pop-ups
ccowin_odfw
It is a Desktop with a Nvidia NVS 310, I think it has also happened both times when I'm remoted into the computer with RDC. I'm actually getting a new computer any day now so I guess I'll see if this fixes itself with the new PC.
