Arcgis PRO DOESN'T detect tin name in the geoprocessing tool LANDXML TO TIN
851
04-27-2023 02:08 PM
ArmandoFreites16
Hello, i have this problem
Tags (3)
Robert_LeClair
Esri Notable Contributor
Looking at the LandXML to TIN geoprocessing tool, the input is the LandXML file, the Output TIN Folder is a folder you want the TIN to be created IN so you'll need to identify the folder rather than a file.  The Output TIN base name is the basename of the resulting TIN to be created.  You read more about it here.
Robert_LeClair
Anthony_Herman
The names show up in the tool, but do not seem to be used in folder creation/naming. The "base Name" is just set to the integer of whatever surface order exists. So how can I reliably match up (in model builder) the surface name and the resultant TIN name?
