arcgis pro custom script tool: how to edit info window for each parameter
2011
06-09-2021 12:50 PM
JaredPilbeam2
MVP Regular Contributor
 I've created a custom script tool. And I want to be able to describe what to do for each parameter. I would think you could edit the little info box that appears when you hover over it. Right now it's blank.
I don't see anywhere in the Tool Properties> Parameters where you could do this.
DavidPike
MVP Frequent Contributor
I think if you right-click on the script tool and 'edit metadata' then the 'Syntax' box is the little icon text.
DavidPike
JaredPilbeam2
That's it, thanks! You can't forget to save in the Metadata tab to keep your changes, I noticed.
