ArcGIS Pro can't detect Layer Package file
2224
06-01-2018 10:43 AM
KellyAllen2
I've created a Layer Package in ArcGIS Pro and would like to open it in a new map. I did not get any warnings about the package and it was created without issues. I can see the .lpkx file using the File Manager but when I try and use Add Data to open the layer package in my new map ArcGIS Pro can't detect it is there. Does anyone have suggestions as to why ArcGIS Pro 2.1.3 can't see my .lpkx file?
TimOrmsby
If you just made the layer packages, click the Refresh button in the upper right corner of the Add Data dialog box and see if that helps.
TimOrmsby
KellyAllen2
Tim,
Thank you. This worked.
