ArcGIS Pro Calculator tool
156
10-20-2021 10:07 AM
KateEkhator74
New Contributor III
Hello,
Am trying to use  the calculate field tool in ArcGIS pro and I am not familiar with the python 3 if then statements and how to use the code block. Please can anyone help with some tips on how to  do this.
Thanks.
JayantaPoddar
MVP Esteemed Contributor
Calculate Field Python examples—ArcGIS Pro | Documentation
You could use if, elif, else statements. e.g.
Expression:
Reclass(!WELL_YIELD!)
Code Block:
def Reclass(WellYield):
    if (WellYield >= 0 and WellYield <= 10):
        return 1
    elif (WellYield > 10 and WellYield <= 20):
        return 2
    elif (WellYield > 20 and WellYield <= 30):
        return 3
    elif (WellYield > 30):
        return 4
Think Location
KateEkhator74
New Contributor III
Thank you.
jcarlson
MVP Frequent Contributor
You might also consider trying Arcade. Arcade translates across to the ArcGIS Online environment, popup expressions, etc., and is worth learning.
- Josh Carlson
Kendall County GIS
