ArcGIS Pro 9.0: How two columns of points are transferred as two fields in the attribute table of polygon layer?
1321
03-04-2022 10:09 PM
JamalNUMAN
Legendary Contributor
As per the screenshot (and the attached data):
  • I have a data that is generated in point layer and polygon layer
  • Each feature of the point layer lies next to a feature from the polygon layer
Now, how the two columns of the point layer are transferred as two fields in the attribute table of the polygon layer?
Jamal Numan
JamalNUMAN
Solved here:
https://community.safe.com/s/question/0D54Q00009M6epwSAB/fme-desktop-2022-how-two-columns-of-points-...
Jamal Numan
DanPatterson
MVP Esteemed Contributor
If the others are in a table, Join based on autocad color, then calculate field to get the joined data into the new columns
... sort of retired...
JamalNUMAN
Unfortunately, the points don’t have the same colors as their corresponding polygons
Jamal Numan
DanPatterson
I doubt you can join on the coordinates, which would leave manual editing I suppose.
JamalNUMAN
Solved here:
Jamal Numan
Bud
Notable Contributor
ArcGIS Pro 9.0? Isn't the latest version 3.0.3?
