I have two features, in the same feature class. The edge I've flagged in red has incorrect z-elevations for the larger feature. The smaller feature has the correct elevations. How can I make this edge of the larger feature align with the edge of the smaller one? Only the z needs to be adjusted, everything else is perfect. I tried setting up a topology for rule area boundary must be covered by boundary of but apparently it can't do this within a feature class because I get a file lock error with no other possible explanation other than the tool doesn't work within a feature class. Do I have to dissect every little feature I want to change into its own separate feature class or is there a better way? Align feature seems likewise useless as the input needs to be in separate feature classes.
