ArcGIS Pro 3.0 and Pictures
5139
13
06-27-2022 11:03 AM
Homer
I recently upgraded to version 3.0 and when I open a old project file that contains pictures they show up blank.
There should be a table instead of a blank box, I was wondering if I should reinstall version 2.9 to fix this?
Thank You.
TomBole
Hi James,
Based on your description I would say this is a different issue than BUG-000150818. I'm not aware of any issues with inserting a picture using the Insert Picture command from the ribbon. I have tested this quite a bit using ArcGIS Pro 3.0. It is possible that there is something specific about your data/file structure/workflow that we did not account for in our testing.
Without additional information I cannot even guess at what the problem might be. Please contact support at https://support.esri.com/en/contact-tech-support. We will keep an eye out.
Thanks!
Tom
TomBole
BrandonCarrick
I am having major issues in 3.0 when exporting layouts to PDF. My Pro Layout will look fine with the right pictures but when I export to PDF the PDF will populate random default pictures. We absolutely do not want to see random pictures on our sheets. The pictures that are supposed to be blank are the ones that are populating these randomly. I had to go back to 2.9 which was a pain because we cannot use much from 3.0. I really would like to use 3.0 because going back has created more issues.
TomBole
Hi Brandon,
Sorry you are running into this issue.
I was able to reproduce a PDF output with the wrong picture - the picture should have been blank - for a map series page where the picture element source was an attachment using ArcGIS Pro version 3.0.3. Unfortunately this is a bug in Pro 3.0. It should be addressed in the Pro 3.1 release.
In the meantime, you can work around the issue by exporting via the Python window instead of the export pane.  You can learn more about exporting a map series via Python here https://pro.arcgis.com/en/pro-app/latest/arcpy/mapping/mapseries-class.htm
Here is a sample script you can paste in the Python window to export all layouts in a project to PDF.
##Export Map Series to PDF
aprx = arcpy.mp.ArcGISProject("CURRENT")
lyt = aprx.listLayouts()[0]
ms = lyt.mapSeries
ms.exportToPDF(f"C:\Temp\{lyt.name}.pdf", "ALL", resolution=300)
print("Done")
Hope this helps!
Tom
