ArcGIS Pro 3.0.3 has GIS Day Tab
621
02-09-2023 12:07 PM
RichardDaniels
I've installed ArcGIS Pro 3.0.3. On first start it is showing a 'GIS Day' tab in the Ribbon. Is anyone else seeing this in the Production Release and how do we turn it off? I know about DAMLS, but hopefully I don't have to edit one and deploy to all machines with Pro 3.0.3.
All my old addins were for ArcGIS Pro 2.9, so should not show even if they are in the Add-In path(s).
Robert_LeClair
Esri Notable Contributor
I've never seen a GIS Day tab on ArcGIS Pro.  I'm currently running ArcGIS Pro 3.0.3 as well.  Regardless, if you want to remove the tab, you can learn how to do it here
AdrianWelsh
MVP Honored Contributor
I haven't seen it either. Can you post a screen shot of what is inside the tab? I'm curious!
RichardDaniels
I guess this could have been in ArcGIS Pro 3.0 which I used for UC 2022, then deleted and reverted to ArcGIS Pro 2.9.5 for production work. That being stated this add-in is not located within my defined Add-in paths.
