ArcGIS Pro 3.0.2 restarts when trying to login into organization protal
493
11-24-2022 09:23 AM
PaoloF
Hi everyone into the Community.
Today I decided to update ArcGIS Pro to version 3.0.2.
Just as additional step after update download, I had to download NET SDK version 6 and to install separately to be able to go till the end of installation.
But the real problem happens when I opened new ArcGIS PRO and tried to sign into organization portal.
At this time it occurs sistematically a crash of the application when the dialog that advices about opening of the browser to complete the login operation appears: it suddenly goes away, ArcGIS Pro closes itself and restarts, reaching again the main windows of the application without any connected user.
Looking at similar case in other posts into community, I found a suggestion to install Access Database Engine, then I tried to rename ESRI folders into AppData/Local and AppData/Roaming user directory, but without any success.
Hope to get successfully suggestion by any of you.
Best and kind regards.
