ArcGIS Pro 3.0.2 - How to apply colormap file .clr to feature class symbology?
1892
7
12-14-2022 09:48 AM
VincentLaunstorfer
I have a single band raster with a color classification I exported to colormap .clr file. Now the .clr file is simple a test file with gridcode and RGB values...
As I converted my single band raster to polygons, I would like to apply the same color classification using the colormap .clr file. How is it possible?
Luke_Pinner
MVP Regular Contributor
Convert your .clr to a .csv with gridcode and rgb fields.  You'll need to do some processing (e.g. in Excel or as a field calculation after you join) to get the separate R G B values into a single text value "rgb(r, g, b)" then join the csv to your feature class and use Attribute-driven color symbology.
How To: Apply Hex or RGB color codes from an attribute field as a feature symbology in ArcGIS Pro
Attribute-driven color in symbology
Luke_Pinner
VincentLaunstorfer
Thanks. It eventually worked. The workflow is rather cumbersome and in addition to the resources mentioned above, follow the Attribute-driven instructions closely:
https://pro.arcgis.com/en/pro-app/latest/help/mapping/layer-properties/attribute-driven-symbology.ht...
RussellGibson_ns
Hi, Vincent.
How did you export to a .clr in ArcGIS Pro?
Alec
For anyone looking
FamoussaDEMBELE
I have a single band raster with a color classification I applied a colormap using .clr file (which had 5 predefined classes from 1 to 5). Now after adding the colormap, I am getting other unwanted classes which are not of my interest as seen below. How do I remove those classes that are not represented on my raster image without changing the colormap settings?Class needed for the colormap.png
VincentLaunstorfer
In the Imagery tab, I used the Raster Functions -> Data Management -> Mask in order to 'mask' unwanted pixels, as shown below. Although, you seem to have lots of unwanted pixel in your example. I would recommend to reclass your raster beforehand to 'group' all unwanted pixels together.
Hope this help
FamoussaDEMBELE
Thank you very much for your feedback.
I tried to reclassify all the unwanted classes to 1 class. However when I export the reclassified data (map) the colormap and import it again, it comes back with the unwanted classes.
