ArcGIS Pro 3.0.1: “table to domain” tool ends up with “The value being added to the CodedValueDomain already exists” error,
1290
08-29-2022 12:41 AM
JamalNUMAN
Legendary Contributor
I couldn’t figure out why “table to domain” tool ends up with “The value being added to the CodedValueDomain already exists” error considering the fact that the geodatabase has no domains
The data is attached
Jamal Numan
RhettZufelt
MVP Notable Contributor
Appears to be because you are using the same field for both Code and Description.
Since you picked Comminity Classification, when it hits the third row, that is "Village Council", but, the second row already assigned "Village Council" so you are trying to insert a duplicated Code value that is not allowed.
R_
RhettZufelt
R_
JamalNUMAN
Great. Thank you for the help
I just summarized the “CommunityClassification_English” field and used it to import the domain values to the geodatabase.
Jamal Numan
